want to all 4 gpio off while restart esp (wifisocket firmware
Which ports did you use ?
Try this code
supla_esp_gpio_hi(B_RELAY1_PORT, 0);
supla_esp_gpio_hi(B_RELAY2_PORT, 0);
supla_esp_gpio_hi(B_RELAY3_PORT, 0);
supla_esp_gpio_hi(B_RELAY4_PORT, 0);
add here:
https://github.com/SUPLA/supla-espressi ... io.c#L1038
but replace B_RELAY*_PORT with your port numbers
add here:
how to replace this "but replace B_RELAY*_PORT with your port numbers"
suppose port number are these:
#define B_RELAY1_PORT 12
#define B_RELAY2_PORT 13
#define B_RELAY3_PORT 14
#define B_RELAY4_PORT 16
<<<<<<<<<<<<<<<<<<<<<so modified code>>>>>>>>>>>>>>>>>>>
or
supla_esp_gpio_hi(B_RELAY12_PORT, 0);
supla_esp_gpio_hi(B_RELAY13_PORT, 0);
supla_esp_gpio_hi(B_RELAY14_PORT, 0);
supla_esp_gpio_hi(B_RELAY16_PORT, 0);
or
supla_esp_gpio_hi(B_RELAY1_12, 0);
supla_esp_gpio_hi(B_RELAY2_13, 0);
supla_esp_gpio_hi(B_RELAY3_14, 0);
supla_esp_gpio_hi(B_RELAY4_16, 0);
please let me know
or
or
please let me know
supla_esp_gpio_hi(12, 0);
supla_esp_gpio_hi(13, 0);
supla_esp_gpio_hi(14, 0);
supla_esp_gpio_hi(16, 0);
For GPIO16 use you should add USE_GPIO16_OUTPUT definition to your board.h file
#define USE_GPIO16_OUTPUT
