Reading MEW-01 driectly
Post Reply
TheViking
Can I read MEW-01 directly ... I don't want to or can't read from the cloud.
What I my options?
1. setup on-prem mqtt broker -> that works but calls for more stuff installed
2. read from the meter directly - on demand ??? *** -> I was told this is not doable ... true?
Contact:
It is not possible. You can only read through the MQTT broker or Supla Cloud.
TheViking
do you have any links to code or videos that can help me get this up and running?
Contact:
Describe what exactly you want to do.
TheViking
<meter type="electric" tag="orno516" brand="orno" model="orno516">
<serial baudrate="9600" parity="E" stopbits="1" timeoutSecs="0.25"/>
<registers>
 mode="" -> defaults: register; unit="" -> defaults: no unit
<register address="0x0000" size="2" name="SerialNumber" decpnt="1" mode="" unit=""/>
<register address="0x0002" size="1" name="ModbusAddress" decpnt="0" unit=""/>
<register address="0x0003" size="1" name="BaudRate" decpnt="1" unit=""/>
<register address="0x0004" size="2" name="SoftwareVersion" decpnt="3" mode="float" unit="" formatter="round2"/>
<register address="0x0006" size="2" name="HardwareVersion" decpnt="3" mode="float" unit="" formatter="round2"/>
<register address="0x0008" size="1" name="CT_Rate" decpnt="1" mode="" unit=""/>
<register address="0x0009" size="2" name="S0_OutputRate" decpnt="0" mode="" unit=""/>
<register address="0x000B" size="2" name="A3" decpnt="0" mode="" unit=""/>
<register address="0x000D" size="1" name="CycleTime" decpnt="0" mode="" unit=""/>
<!-- volts & frequency -->
<register address="0x000E" size="2" name="L1_Voltage" decpnt="2" mode="float" unit="Volts" formatter="round2"/>
<register address="0x0010" size="2" name="L2_Voltage" decpnt="2" mode="float" unit="Volts" formatter="round2"/>
<register address="0x0012" size="2" name="L3_Voltage" decpnt="2" mode="float" unit="Volts" formatter="round2"/>
<register address="0x0014" size="2" name="GridFreqHz" decpnt="2" mode="float" unit="Hz" formatter="round2"/>
<!-- amps -->
<register address="0x0016" size="2" name="L1_Amps" decpnt="2" mode="float" unit="Amps" formatter="round2"/>
<register address="0x0018" size="2" name="L2_Amps" decpnt="2" mode="float" unit="Amps" formatter="round2"/>
<register address="0x001A" size="2" name="L3_Amps" decpnt="2" mode="float" unit="Amps" formatter="round2"/>
<!-- reactive power -->
<register address="0x001C" size="2" name="TotalActivePower" decpnt="0" mode="float" unit="Watts" formatter="times1000r2"/>
<register address="0x001E" size="2" name="L1_ActivePower" decpnt="0" mode="float" unit="Watts" formatter="times1000r2"/>
<register address="0x0020" size="2" name="L2_ActivePower" decpnt="0" mode="float" unit="Watts" formatter="times1000r2"/>
<register address="0x0022" size="2" name="L3_ActivePower" decpnt="0" mode="float" unit="Watts" formatter="times1000r2"/>
<register address="0x0024" size="2" name="TotalReactivePower" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<register address="0x0026" size="2" name="L1_ReactivePower" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<register address="0x0028" size="2" name="L2_ReactivePower" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<register address="0x0030" size="2" name="L3_ReactivePower" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<!-- power factor -->
<register address="0x0034" size="2" name="TotalPowerFactor" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<register address="0x0036" size="2" name="L1_PowerFactor" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<register address="0x0038" size="2" name="L2_PowerFactor" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<register address="0x003A" size="2" name="L3_PowerFactor" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<!-- active energy -->
<register address="0x0100" size="2" name="TotalActiveEnergy" decpnt="2" mode="float" unit="kWh" formatter="round2"/>
<register address="0x0102" size="2" name="L1_TotalActiveEnergy" decpnt="2" mode="float" unit="kWh" formatter="round2"/>
<register address="0x0104" size="2" name="L2_TotalActiveEnergy" decpnt="2" mode="float" unit="kWh" formatter="round2"/>
<register address="0x0106" size="2" name="L3_TotalActiveEnergy" decpnt="2" mode="float" unit="kWh" formatter="round2"/>
<!-- reactive energy -->
<register address="0x0118" size="2" name="TotalReactiveEnergy" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<register address="0x011A" size="2" name="L1_TotalReactiveEnergy" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<register address="0x011C" size="2" name="L2_TotalReactiveEnergy" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
<register address="0x011E" size="2" name="L3_TotalReactiveEnergy" decpnt="2" mode="float" unit="kVArh" formatter="round2"/>
</registers>
</meter>
this is a sample meter register def. file from a my software ... as you can this this is for orno 516 model ... I want to be able to read same fields from MEW-01 meter? I have need to read at max every 2 minutes or so.
Contact:
As I wrote above. You can use MQTT for this, which requires connecting to the MQTT Broker or use the RestFul API.
https://cloud.supla.org/ -> Integrations. In the "MY OAUTH APPS" tab you can find a link to the documentation. For MQTT, you can bypass our cloud and connect MEW-01 directly to your own local mqt broker. Personally, I encourage you to use MQTT due to the limits of requests to the API.
TheViking
tnx
Post Reply
Return to “General discussion”
