SONOFF
gaurav
Mon May 08, 2017 1:19 pm
Can you build a firmware which can replicate the gate module firmware on SONOFF SV?
Thank you in Advance. :)
Contact:
Mon May 08, 2017 1:23 pm
You can build by yourself using ESP8266 - IOT SDK
https://www.supla.org/pl/download
Zybi
Mon May 08, 2017 7:46 pm
Or ... You can upload and test this software:
https://github.com/zchmielak/ESP8266/bl ... 2.0_p5.rar
gaurav
Mon Jun 26, 2017 6:27 am
When I build sonoff firmware from SDK sonoff doesn't boots up. I tried the same firmware on Nodemcu with no luck. I even tried with cfg with pullup but it didn't solved the issue. Am I missing anything?
Contact:
Mon Jun 26, 2017 9:27 am
What do you see on the console ?
gaurav
Mon Jun 26, 2017 11:13 am
how can I check it on console?
Contact:
Mon Jun 26, 2017 12:57 pm
You can use putty.
Speed rate 74880
gaurav
Tue Jul 04, 2017 12:39 pm
This is what I got when I reset the nodemcu.
Contact:
Tue Jul 04, 2017 1:02 pm
Use esp_init_data_default.bin
Contact:
Erase all flash and use esp_init_data_default.bin
Post Reply
Return to “General discussion”
