Adding Supla Devices to SuplaRaspberryCloud
Post Reply
JGellert
Hello,
I wanted to create my own Supla Cloud which is running from a raspberrypi zero W.I got to the point that everything starts up ,i can log in into the cloud ,but whenever i try to add a supla device(configuring directly the device to point to the raspberry) i get the following error message on the device:
Connecting....,Protocol version error,WiFi
I have the latest supla docker which is available ,also i upgraded the supla device to the latest firmaware 2.7.24.
What i`m doing wrong?I`m a newbie in supla...
Contact:
Update the server to the latest version
JGellert
I runned the following command:
cd supla-docker
git pull
./supla.sh upgrade
Still the same issue.
Is there another way to update the server?
Contact:
Have you restarted the containers?
What version of the cloud do you see when logging in?
JGellert
So i managed to solve the problem.Something was not up to date for sure the server.
I modified inside the docker compose arm file the version of the image which was pulling from the docker site.
After upgrading i managed to add the device inside the local cloud.Maybe somebody should update on github in order to be able to take the latest image from docker.I will try to leave a note or something.
Thanks for the help!
Post Reply
Return to “Help”
