SOnOff TH10 not booting with Supla. Help!
MilanGajic wrote: Wed Nov 13, 2019 10:44 pm ...
can i just use the one from here: https://github.com/SUPLA/ESP8266/tree/master/sonoff
Yes you can.
MilanGajic wrote: Wed Nov 13, 2019 10:53 pm flashed again ... still nothing :(
Do you upload official files from github or those from googledrive?
1. ERASE
2. RESET (USB OFF USB ON)
3. FLASH
MilanGajic
lesny8 wrote: Wed Nov 13, 2019 10:58 pm Do you upload official files from github or those from googledrive?
google drive.
i go to https://www.supla.org/en/download
scroll down to "ITEAD SONOFF TH10/TH16"
click on DOWNLOAD (https://www.supla.org/download/sonoff_th-firmware.zip)
this link redirects to https://drive.google.com/file/d/0B3DJSA ... RXSWM/view
so ...
I just downloaded the boot* and sonoff* files again from:
https://github.com/boseji/SUPLA-ESP8266 ... /sonoff_th
(no mention of "esp_init_data_default.bin" on github either)
erased the chip
reflashed new files with the same settings
2019-11-14 00_07_40-ESP8266 DOWNLOAD TOOL V3.6.6.jpg (46.74 KiB) Viewed 3688 times
unplugged FTDI
connected module to mains
... NO BUENO :?
<this is becoming frustrating>
PS: on every occasion until now i've also tried holdign down the button for 6 seconds, with no success
MilanGajic
Patryk wrote: Wed Nov 13, 2019 11:00 pm 1. ERASE
3. FLASH
yes, i did this every time
Set SPI MODE - DOUT
The googledrive version must have been compiled earlier. Links on the site are not updated and can not be point to te last builds.
Do you have putty?
Run putty or some terminal on the same com port with speed 74880 and see what will be displayed after power on.
Uploading a compiled software is not a difficult thing, but sometimes we make a small mistake and it doesn't go as it should.
MilanGajic
Patryk wrote: Wed Nov 13, 2019 11:19 pm Set SPI MODE - DOUT
YES!!!!!
I see it in the dashboard now. :P :D
THANKS A BUNCH GUYS !
I guess github needs a little bit of an update ;-)
It just does not see my temperature/humidity sensor ... unsuported type ? mine is a SI7021 ... but the panels show DS18B20 (active but no data) and AM2301 (inactive, not available, X?)
2019-11-14 00_43_36-Thuis _ SONOFF-TH10 - SUPLA Cloud.jpg (43.2 KiB) Viewed 3675 times
MilanGajic
Related thread ... also regarding SI7021 sensor
viewtopic.php?f=8&t=5540&hilit=SI7021&start=10
Cool :D
Unfortunately SI7021 is not supported.
AM2301 is off. Click on him and select his function.
I'm not sure, but in this software only one measurement channel can be active.
MilanGajic wrote: Thu Nov 14, 2019 12:00 am Related thread ... also regarding SI7021 sensor
You can compile soft and upload through the Arduino IDE, but you need a minimum of programming knowledge to do this. If you feel up to it, give it a try ;)
Post Reply
Return to “Help”
