Hello everyone,
I'm new to this forum and to Supla ...and I have a little problem.
I've been trying to flash Supla (sonoff_th10_user1.1024.new.2.bin) to my Sonoff th10, but I just can't get it to boot after flashing.
I'm using NodeMCU and the flashing seems to go allright.
When it's done, I unplug the FTDI adapter and connect it to mains (230V).
The TH10 does not boot, no blinking leds, no WiFi AP, button does not work.
If I reflash Tasmota everything works just fine.
Thank you in advance for any help.
Best regards,
Milan
SOnOff TH10 not booting with Supla. Help!
You used the wrong address for the firmware file and didn't upload the chip initialization file. Follow the readme.txt file.
https://github.com/SUPLA/ESP8266/tree/master/sonoff_th
Edit:
Use FlashDownloadTools
Edit:
Ok, thank you lesny8.
I actually just figured it out myself and followed the guide here:
https://www.smartnydom.pl/wgrywanie-fir ... do-sonoff/
Unfortunately still the same issue
I tried DOUT and QIL
Upload one more file:
esp_init_data_default.bin---->0xfc000
In the readme.txt file is written:
boot_v1.5.bin -------->0x00000
sonoff_th10_user1.1024.new.2.bin---->0x01000
BAUDRATE: 115200
Flash Size: 1MByte (8Mbit)
Flash speed: 40Mhz
SPI Mode: DIO
Upload all files on these settings.
BAUDRATE: 115200
Flash speed: 40Mhz
SPI Mode: DIO
@lesny8:
i tried using the flash_download_tools, but got the same results: reflashed TASMOTA ... still works
readme says this:lesny8 wrote: ↑Wed Nov 13, 2019 10:36 pmUpload one more file:
BAUDRATE: 115200
Flash speed: 40Mhz
SPI Mode: DIO
SUPLA FOR ITEAD SONOFF TH10/16
TH10
TH16
sonoff_th16_user1.1024.new.2.bin---->0x01000
BAUDRATE: 115200
Flash Size: 1MByte
Flash speed: 40Mhz
SPI Mode: QIO
esp_init_data_default.bin is not in the ZIP file ... where do I get it?
can i just use the one from here: https://github.com/SUPLA/ESP8266/tree/master/sonoff
I downloaded from this link (provided on the Supla download page):
https://drive.google.com/file/d/0B3DJSA ... RXSWM/view
YesMilanGajic wrote: ↑Wed Nov 13, 2019 10:44 pmlesny8 wrote: ↑Wed Nov 13, 2019 10:36 pmUpload one more file:
BAUDRATE: 115200
Flash speed: 40Mhz
SPI Mode: DIO
