Hello Everybody,
I tried to download and install a supla cloud server using the Supla-Server.ova. I am not able to use it. Is there someone that can help me with a guide or other download?
Thanks in advance.
Supla ova Virtual Machine
What processor do you have?
PS.
Instead of a virtual machine, you can use the docker.
https://github.com/SUPLA/supla-docker
PS.
Thanks for your reply. So I need to install debian server VM and then I've to do the procedure in your link. Isn't it?
You can use any host to run a SUPLA working in containers.
However, the most convenient will be Debian. You can also use Container Station in QNAP if you have one.
Sorry, can you please help me with the attached error?
- Attachments
- screen.png (43.78 KiB) Viewed 6801 times
You have something on the port 80 already. Check out the Troubleshooting section here https://github.com/SUPLA/supla-docker/b ... leshooting
Supla ova Virtual Machine You can use any host to run a SUPLA working in containers. However, the most convenient will be Debian. You can also use Container Station in QNAP if you have one
WBMShop & learn about the perfect smart home devices products for your home in 2020. 30-Day No-Hassle Returns & 20% Off Your First Order.
