Page 5 of 6
Re: SONOFF
Posted: Thu May 31, 2018 11:12 am
by gaurav
I flashed firmware from your link and it worked but firmware from the IoT SDK is not working. What could be the reason?
Re: SONOFF
Posted: Mon Jun 04, 2018 11:53 am
by gaurav
The firmware which I am flashing is built from IoTSDK. I have installed the latest SDK still the firmware is getting flashed with proper configuration as discussed earlier but doesn't works.
Kindly help.
Re: SONOFF
Posted: Fri Jun 15, 2018 7:17 am
by pzygmunt
What do you see on the console ?
Re: SONOFF
Posted: Fri Jun 22, 2018 1:08 pm
by gaurav
I didn't checked the console. But I flashed firmware next day and it worked. I don't know what happened but it worked.
Can you tell me that is there anyway to integrate the wall switch to sonoff so that I can control it locally.
Is there anyway?
Re: SONOFF
Posted: Fri Jun 22, 2018 1:18 pm
by pzygmunt
You can connect wall switch to the sonoff button.
Re: SONOFF
Posted: Fri Jun 22, 2018 1:43 pm
by gaurav
Not like using sonoff button. But using live or neutral wire connection from the wall switch to sonoff. I have seen some devices which provide live wire input switch so that we can use the existing switches. Like this device.
Re: SONOFF
Posted: Fri Jun 22, 2018 1:46 pm
by pzygmunt
I'm sorry but I do not understand what you want to do.
Re: SONOFF
Posted: Fri Jun 22, 2018 1:50 pm
by gaurav
I want to integrate wall switch to the devices like sonoff so that I can control fans and lights from supla application as well as from wall switch.
Re: SONOFF
Posted: Thu Jul 12, 2018 8:32 am
by gaurav
I have changed #define CFG_BTN_PRESS_COUNT 10 to #define CFG_BTN_PRESS_COUNT 5 still it takes 10 press to enter config mode. What could be the reason?
Re: SONOFF
Posted: Thu Jul 12, 2018 8:35 am
by pzygmunt
gaurav wrote: ↑Thu Jul 12, 2018 8:32 am
BTN is BISTABLE ?
