SONOFF
gaurav
Thu May 31, 2018 11:12 am
I flashed firmware from your link and it worked but firmware from the IoT SDK is not working. What could be the reason?
gaurav
Mon Jun 04, 2018 11:53 am
The firmware which I am flashing is built from IoTSDK. I have installed the latest SDK still the firmware is getting flashed with proper configuration as discussed earlier but doesn't works.
Kindly help.
Contact:
Fri Jun 15, 2018 7:17 am
What do you see on the console ?
gaurav
Fri Jun 22, 2018 1:08 pm
I didn't checked the console. But I flashed firmware next day and it worked. I don't know what happened but it worked.
Can you tell me that is there anyway to integrate the wall switch to sonoff so that I can control it locally.
Is there anyway?
Contact:
Fri Jun 22, 2018 1:18 pm
You can connect wall switch to the sonoff button.
gaurav
Fri Jun 22, 2018 1:43 pm
Not like using sonoff button. But using live or neutral wire connection from the wall switch to sonoff. I have seen some devices which provide live wire input switch so that we can use the existing switches. Like this device.
Contact:
Fri Jun 22, 2018 1:46 pm
I'm sorry but I do not understand what you want to do.
gaurav
Fri Jun 22, 2018 1:50 pm
I want to integrate wall switch to the devices like sonoff so that I can control fans and lights from supla application as well as from wall switch.
gaurav
Thu Jul 12, 2018 8:32 am
I have changed #define CFG_BTN_PRESS_COUNT 10 to #define CFG_BTN_PRESS_COUNT 5 still it takes 10 press to enter config mode. What could be the reason?
Contact:
Thu Jul 12, 2018 8:35 am
BTN is BISTABLE ?
Post Reply
