How can I eliminate this bug?
https://www.youtube.com/watch?v=MWwRv0Z ... e=youtu.be
Second - I can not disable the second device, it still works svr2
Thank you very much for your work!
Elimination of bugs
Hello AnatoliyRome!AnatoliyRome wrote: ↑Tue Apr 25, 2017 9:00 pm How can I eliminate this bug?
I just curious what type of controller did you use for that project?
It seems like PLC or another industrial controller, isn't it?
How could you flash SUPLA-firmware into that device?
Cheers!
Hi.
Please describe step by step how to reproduce this problem.
Also paste your arduino code.
Hi! I still do not understand how this happens.
But if done as a video then this also happens https://www.youtube.com/watch?v=V3FXpVhl9wU
Excuse for troubling
this is controllinoastonix wrote: ↑Wed Apr 26, 2017 11:38 amHello AnatoliyRome!AnatoliyRome wrote: ↑Tue Apr 25, 2017 9:00 pm How can I eliminate this bug?
Cheers!
#include <SPI.h>
#include <Ethernet.h>
#include <SuplaDevice.h>
#include "Controllino.h"
SuplaDevice.addRelay(CONTROLLINO_RELAY_00);
SuplaDevice.addRelay(CONTROLLINO_RELAY_01);
SuplaDevice.addRollerShutterRelays(CONTROLLINO_R6,
CONTROLLINO_R7);
SuplaDevice.addRelay(CONTROLLINO_D0,CONTROLLINO_AI0,false,true,250 );
SuplaDevice.addRelay(CONTROLLINO_D1,CONTROLLINO_AI1,false,true,250 );
SuplaDevice.addRelay(CONTROLLINO_D2,CONTROLLINO_AI2,false,true,250 );
Sometimes all channels can change the value without an explicit motive.
Probably this is problem of SuplaDevice Arduino library.
I try to reproduce it on my side.
As it seems to me after the server is rebooted
If you add the condition - server overload = overloading arduino?
