ESP8266 Problem Blue LED Flash Slowly
Post Reply
CdrHacker
Sun May 22, 2016 8:17 am
Hey Guys i'm From Aus Love the project.
Been using Blynk for my garage door but with extra coding for feedback loop hated it found you guys.
Anyway i am using NodeMCU its a ESP8266 with built in FTDI and voltage step down great product.(find info here https://nodemcu.readthedocs.io/en/dev/)
I could flash fine then put in to config mode and upload SSID,Pass,server... i can see it on the network even, then after restarting the Blue led just flashes slower than when in config mode and it wont even go back into config mode so i can see status.
any ideas :?:
Thanks in Advance
jangolen
Mon May 23, 2016 6:27 am
Is it connect to you network after restart? Check it in your router.
Check server for correct server adress : not "srv", right - svr1.supla.org. ID and pass for Access Identifiers from your cloud.supla.org
Contact:
Mon May 23, 2016 7:17 am
What do you see in the console?
Check button connection.
CdrHacker
Mon May 23, 2016 7:26 am
Yes it is connected to my network after restating however how do i get a console connection to it? also the button is not pressed
Contact:
Mon May 23, 2016 7:30 am
Run Putty
http://www.putty.org/
Set connection type to "Serial"
Select serial port where is connected esp8266 module (via FTDI converter).
Set speed to 74880
Click Open
CdrHacker
Sat May 28, 2016 4:29 am
WiFi Status: 5
client handshake start.
devconn_disconnect_cb
state: 5 -> 0 (0)
rm 0
del if0
usl
¢„*«P*V¡¡ET©«´¥T«ª«*¥u´U+UZªZªT¢¤«TQT¥QQ©©jPE*E*µuª¥…¢üZT¥(EŠª«ªQ*UEu¢…ªªÅQBªµ¨U¥¨®UP¡QüZT¥(UEŠª«ªQZªEu¢…ªªÅU(Bªµ(U©µuª©ÅZT¥(EŠª«ªQZªEªj*QZªÅªµ+Õ­…-+PUUP´TT
SDK ver: 1.5.0 compiled @ Nov 27 2015 13:37:51
phy ver: 484, pp ver: 9.5
Starting
CFG READ SUCCESS!
mode : sta(18:fe:34:d3:f4:8c)
add if0
f r0, WiFi Status: 1
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 8
cnt
connected with Steve, channel 6
dhcp client start...
ip:192.168.0.14,mask:255.255.255.0,gw:192.168.0.1
WiFi Status: 5
state: 5 -> 0 (0)
rm 0
del if0
usl
Starting
CFG READ SUCCESS!
add if0
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 8
cnt
WiFi Status: 5
state: 5 -> 0 (0)
rm 0
del if0
usl
Starting
CFG READ SUCCESS!
add if0
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 8
cnt
WiFi Status: 5
state: 5 -> 0 (0)
rm 0
del if0
usl
Starting
CFG READ SUCCESS!
add if0
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 8
cnt
WiFi Status: 5
Just keeps repeating this.
Contact:
Sat May 28, 2016 7:26 am
For some reasons ESP lose estabilished connection with your wifi network. when it happen Supla software perfofm ESP restart so you don't have enought time to hold the button pressed. Turn off your WiFi network for a moment and then press the button.
Contact:
Sat May 28, 2016 7:27 am
....Maybe wifi coverage is too weak?
Post Reply
