Sonoff Touch
scorpio
Anyone?
elmaya
scorpio wrote: Sat Jun 06, 2020 6:45 pmAnyone?
patience please
scorpio
elmaya wrote: Mon Jun 08, 2020 10:08 am
patience please
OK
elmaya
scorpio wrote: Mon May 11, 2020 6:36 pm Elmaya, I have uploaded your software to my brand new Sonoff TX T2EU1C, and is the best.
However, I think I found small bug.
If Sonoff is connected to my Wi-Fi network, ewerything is fine. When I unplug cable from WAN port of my router, it work not as it should. Response to touch is sporadic.
But when Sonoff is not connected to any Wi-Fi, ewerything is great. Like you say: full offline functionality.
Could you check that?
@scorpio if you were so kind to try this version of the software.
it should work perfectly even when you unplug cable from WAN port of the router.
(WiFi network but without internet connection)
remember that you can easily update through the web browser "OTA"
http://xx.xx.xx.xx:81/update
where "xx.xx.xx.xx" would be the Sonoff Touch IP on your local network.
supla_Touch_T1_B_DOUT_8Mbit.rar
scorpio
@elmaya I've tested this software version. It seems fine. Thank you very much. It was worth the wait.
A small note, this is the version with inverted LED function, like you described in first post.
IMHO this ist the best soft for Sonoff Touch.
elmaya
scorpio wrote: Thu Jun 11, 2020 1:34 pm.
possibly not.
do you want it with the inverted led?
scorpio
elmaya wrote: Sun Apr 12, 2020 2:15 pm
with inverted LED function:
Led off = not connected-connecting.
led blinks = WiFiConfig.
Led on = OK
LED in my Sonoff works exactly that way and I am very satisfied. Thank you once again
Remi
@elmaya, did You consider to add additional function selection for at least one touch button to be able to activate direct link?
elmaya
the truth is that I have not thought about that.
adam.repo
Remi wrote: Fri Aug 21, 2020 9:34 pm @elmaya, did You consider to add additional function selection for at least one touch button to be able to activate direct link?
that would be amazing.
Return to “Ideas and concepts”
