Supla lc technology relay
vitia
I'm having trouble adding a device.
It seems to me that I uploaded the software well - ESP broke the network. I registered, entered the password etc. So far it looked ok. But I don't know how to add the device. Should I hold S2 to pair it?
vitia
All works well - thank you Elmaya!
AVAYA
Good morning. Maybe someone will help me with the 1 relay module and the TLE7250 integrated circuit. Unfortunately, uploading it here does not control the relay.
elmaya
AVAYA wrote: Sun Oct 31, 2021 4:03 pm Good morning. Maybe someone will help me with the 1 relay module and the TLE7250 integrated circuit. Unfortunately, uploading it here does not control the relay.
what's this about the TLE7250 integrated circuit?
what module do you have?
AVAYA
Same as in the attached photos
Fryga
Serio?
https://pdacontrolen.com/review-module- ... ation-com/
Wiecej zabawy ale powinno działać.
Turn Off First Relay A0 01 00 A1 [“0xA0″,”0x01″,”0x00″,”0xA1”]
Turn On First Relay A0 01 01 A2 [“0xA0″,”0x01″,”0x01″,”0xA2”]
Turn Off Second Relay A0 02 00 A2 [“0xA0″,”0x02″,”0x00″,”0xA2”]
Turn On Second Relay A0 02 01 A3 [“0xA0″,”0x02″,”0x01″,”0xA3”]
Turn Off Third Relay A0 03 00 A3 [“0xA0″,”0x03″,”0x00″,”0xA3”]
Turn Off Third Relay A0 03 01 A4 [“0xA0″,”0x03″,”0x01″,”0xA4”]
Turn Off Fourth Relay A0 04 00 A4 [“0xA0″,”0x04″,”0x00″,”0xA4”]
Turn On Fourth Relay A0 04 01 A5 [“0xA0″,”0x04″,”0x01″,”0xA5”]
caxap
Hi
Does the process of connecting with the supla application look like in other devices?
I can't get the LED flashing fast like the app suggests
Contact:
What device?
caxap
the same as the author's device with ESP8266EX
Contact:
What software?
Post Reply
