Page 6 of 7
Re: Supla 16 X relay -- esp8266 + mcp23017
Posted: Sun Aug 30, 2020 11:51 pm
by elmaya
LukaszH wrote:
Sun Aug 30, 2020 7:36 pm
Hi, it is possible to add to the software: CHANNELSTATE (viewtopic.php?f=18&t=6878) ?
Probably yes, I'll check when I have some free time. ;)
EDIT:
here it is if you want to test.
Posted: Sat Sep 12, 2020 7:00 pm
by LukaszH
EDIT:
I didn't even notice that it is already updated :) Next week I will be able to test, but it will probably work fine as always
Posted: Sun Sep 13, 2020 10:44 am
by elmaya
It will be that lately I have a reputation for taking months. :lol: :lol: :lol:
Posted: Mon Sep 14, 2020 8:31 pm
by LukaszH
I am just after short tests and i have small issue:
1. Soft is without 3 sensors but with thermometer (DS) - for me better is with sensors and without DS
2. Right now only thermometer have info (CHANNELSTATE) - other channel are without info.
3. OTA and evrything else work fine :)
Can I count on changes in the software with 3 sensors? post from 02.06.2020 :)
Posted: Mon Sep 14, 2020 11:47 pm
by elmaya
I have only adapted the latest version of my software to the latest version of Supla dev library.
have you removed the module from the cloud?
you have to delete and re-add for the changes to take effect.
Posted: Tue Sep 15, 2020 7:12 pm
by LukaszH
Right, after cleaning the cloud and reinstalling the software (erase esp), everything works fine - thank you :)
Is only the sensors channel intended to have additional information ?
Can you tell me which pin is for the DS thermometer? and does something mean the letter _B_ in the file name? - It wasn't there before? 8-)
below is a picture of what it looks like:
16 apka.jpg (127.69 KiB) Viewed 535 times
and here is the motherboard that I designed for your soft (ordered in LCPCB)
Posted: Tue Sep 15, 2020 8:10 pm
by elmaya
the letter B is to differentiate the version.
DS connected to Gpio3 "RX"
Posted: Sat Sep 19, 2020 1:05 pm
by kosa24
Hi.
Could you please share the code for the latest version with relays, buttons and sensors? I need to build 8 relays, 8 buttons and 5 sensors on one mcp. There is a code on the first page, but no buttons. By the way - great job, thanks.
Posted: Sat Sep 19, 2020 4:38 pm
by elmaya
here it is. ;)
this is the current version: Supla_16x16_3NO_DS_B
#include <SuplaDevice.h>
#include <supla/io.h>
#include <supla/sensor/normally_open.h>
#include <supla/sensor/DS18B20.h>
#include <Adafruit_MCP23017.h>
#include <WiFiManager.h>
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <ESP8266TrueRandom.h>
#include <WiFiClientSecure.h>
Supla::ESPWifi wifi("", "");  //------ Do not change----wifimanager takes care------
extern "C"
#include "user_interface.h"
//#define D0 16  //no internal pullup resistor
//#define D1  5
//#define D2  4
//#define D3  0  //must not be pulled low during power on/reset, toggles value during boot
//#define D4  2  //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15  //must not be pulled high during power on/reset
#define BTN_COUNT 16
int wificonfig_pin = 0;   //D3
int led_pin = 16;          //D0
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 5000;               // ---------------------- config delay 5 seconds ---------------------------
char Supla_server[81]=("Set server address");
char Email[81]=("set email address");
char Supla_name[81];
char Supla_status[51];
bool initialConfig = false;
bool state10 = true;
bool starting = true;
bool monostable = false;
int s;
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
const int EEPROM_MIN_ADDR = 20;
const int EEPROM_MAX_ADDR = 299;
const int max_cr = 81;
byte uuidNumber[16]; // UUIDs in binary form are 16 bytes long
static const char logo[] PROGMEM = "<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>";
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
WiFiManager wifiManager;
Adafruit_MCP23017 mcp;
Adafruit_MCP23017 mcp2;
typedef struct {
  int pin;
  char last_val;
  int ms;
  unsigned long last_time;
} _btn_t;
_btn_t btn[BTN_COUNT];
class MyMcp23017 : public Supla::Io {
  public:
    void customDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
      if ((pin >= 100)&& (pin <= 115)){
        mcp.digitalWrite(pin - 100, val);
         if (state10 == false){
           if( btn[channelNumber].ms < 10 ){
             EEPROM.write(pin, val);
             EEPROM.commit();
           if ((monostable == false) && (SuplaDevice.channel_pin[channelNumber].DurationMS != btn[channelNumber].ms) && (!val)) {
            int durationMS = SuplaDevice.channel_pin[channelNumber].DurationMS;
               Serial.print("button_duration: ");Serial.print(durationMS);
               Serial.print(" button: ");Serial.println(channelNumber);
               EEPROM.put((channelNumber * 10) + 400, durationMS);
               EEPROM.commit();
               btn[channelNumber].ms = durationMS;
         monostable = false;
         return;
      if (pin <= 99) {
        return ::digitalWrite(pin,val);
   int customDigitalRead(int channelNumber, uint8_t pin) {
        return mcp.digitalRead(pin - 100);
      if (pin <= 99){
        return ::digitalRead(pin);
}MyMcp23017;
void supla_btn_init() {
  mcp2.begin(1);
   for(int a=0;a<BTN_COUNT;a++)
    if (btn[a].pin > 0) {
        mcp2.pinMode(btn[a].pin-1, INPUT);
        mcp2.pullUp(btn[a].pin-1, HIGH);  // turn on a 100K pullup internally
        btn[a].last_val = mcp2.digitalRead(btn[a].pin-1);
        btn[a].last_time = millis();
void mcp_btn() {
  char v;
  unsigned long now = millis();
           v = mcp2.digitalRead(btn[a].pin-1);
        if (v != btn[a].last_val && now - btn[a].last_time ) {
           btn[a].last_val = v;
           btn[a].last_time = now;
           if (v==0)
              delay(75);
               if (mcp2.digitalRead(btn[a].pin-1)==0) {
                if ( btn[a].ms > 0 ) {
                     monostable = true;
                     SuplaDevice.relayOn(a, btn[a].ms);
                     Serial.println(" monostable");
                 } else {
                 if ( mcp.digitalRead(a) == 1 ) {
                  SuplaDevice.relayOff(a);
                  Serial.print("BTN Switsh off relay ");
                  Serial.println(a + 1);
                 } else {
                  SuplaDevice.relayOn(a, 0);
                  Serial.print("BTN Switsh on relay ");
void saveConfigCallback () {
  shouldSaveConfig = true;
   digitalWrite(led_pin, LOW);
   WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81,"required");
   WiFiManagerParameter custom_Email("email", "Email", Email, 81,"required");
   WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 81,"required");
   WiFiManagerParameter custom_Supla_status("status", "Supla Last State", Supla_status, 51,"readonly");
   wifiManager.setBreakAfterConfig(true);
   wifiManager.addParameter(&custom_Email);
   wifiManager.addParameter(&custom_Supla_name);
   wifiManager.addParameter(&custom_Supla_status);
   wifiManager.setCustomHeadElement(logo);
   wifiManager.setMinimumSignalQuality(8);
   //wifiManager.setShowStaticFields(true); // force show static ip fields
   //wifiManager.setShowDnsFields(true);    // force show dns field always
   wifiManager.setConfigPortalTimeout(300);
   if (!wifiManager.startConfigPortal("Supla_16X16")) { Serial.println("Not connected to WiFi but continuing anyway.");} else { Serial.println("connected...yeey :)");}
    strcpy(Email, custom_Email.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    if(strcmp(Supla_server, "get_new_guid_and_authkey") == 0){
      Serial.println("new guid & authkey.");
      EEPROM.write(300, 0);
      EEPROM.commit();
      delay(100);
      ESP.reset();
  if (shouldSaveConfig) {
    if (eeprom_write_string(20, Supla_server))Serial.println("stored server");
    if (eeprom_write_string(105, Email))Serial.println("stored Email");
    if (eeprom_write_string(200, Supla_name))Serial.println("stored name");
    WiFi.mode(WIFI_STA);
    delay(5000);
    ESP.restart();
  WiFi.softAPdisconnect(true);
  digitalWrite(led_pin, HIGH);
boolean eeprom_is_addr_ok(int addr) {
  return ((addr >= EEPROM_MIN_ADDR) && (addr <= EEPROM_MAX_ADDR));
boolean eeprom_write_bytes(int startAddr, const byte* array, int numBytes) {
  int i;
  if (!eeprom_is_addr_ok(startAddr) || !eeprom_is_addr_ok(startAddr + numBytes)) {
    return false;
  for (i = 0; i < numBytes; i++) {
    EEPROM.write(startAddr + i, array[i]);
 EEPROM.commit();
   return true;
boolean eeprom_write_string(int addr, const char* string) {
  int numBytes;
  numBytes = strlen(string) + 1;
  return eeprom_write_bytes(addr, (const byte*)string, numBytes);
boolean eeprom_read_string(int addr, char* buffer, int bufSize) {
    byte ch;
    int bytesRead;
  if (!eeprom_is_addr_ok(addr)) {return false;}
  if (bufSize == 0) { return false;}
  if (bufSize == 1) {buffer[0] = 0;return true;}
  bytesRead = 0;
  ch = EEPROM.read(addr + bytesRead);
  buffer[bytesRead] = ch;
  bytesRead++;
  while ( (ch != 0x00) && (bytesRead < bufSize) && ((addr + bytesRead) <= EEPROM_MAX_ADDR) ) {
    bytesRead++;
  if ((ch != 0x00) && (bytesRead >= 1)) {
    buffer[bytesRead - 1] = 0;
  return true;
void status_func(int status, const char *msg) {    //    ------------------------ Status --------------------------
  if (s != status){
    s = status;
      if (s != 10){
        strcpy(Supla_status, msg);
void guid_authkey(void) {
  if (EEPROM.read(300) != 60){
    int eep_gui = 301;
    ESP8266TrueRandom.uuid(uuidNumber);
    String uuidString = "";
    for (int i = 0; i < 16; i++) {
      int topDigit = uuidNumber[i] >> 4;
      int bottomDigit = uuidNumber[i] & 0x0f;
      uuidString += "0123456789abcdef"[topDigit];
      uuidString += "0123456789abcdef"[bottomDigit];
    int length_uuid = uuidString.length();
    for (int i = 0; i < length_uuid; ++i) {
      EEPROM.put(eep_gui + i, uuidString[i]);
    int eep_aut = 341;
    String uuidString2 = "";
      uuidString2 += "0123456789abcdef"[topDigit];
      uuidString2 += "0123456789abcdef"[bottomDigit];
    int length_uuid2 = uuidString2.length();
    for (int i = 0; i < length_uuid2; ++i) {
      EEPROM.put(eep_aut + i, uuidString2[i]);
    EEPROM.write(300, 60);
    EEPROM.commit();
    eeprom_write_string(20, Supla_server);
    eeprom_write_string(105, Email);
    eeprom_write_string(200, Supla_name);
    delay(0);
  read_guid();
  read_authkey();
  Serial.print("GUID : ");Serial.println(read_guid());
  Serial.print("AUTHKEY : ");Serial.println(read_authkey());
String read_guid(void) {
  String read_eeprom = "";
  int i, ii = 0;
  int eep_star = 301;
  int end_guid = eep_star + SUPLA_GUID_SIZE;
  String temp_read = "0x";
  for (i = eep_star; i < end_guid + 16;  i = i + 1) {
    temp_read += char(EEPROM.read(i));
    read_eeprom += char(EEPROM.read(i));
    if ( (i % 2) == 0) {
      char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      GUID[ii] = strtoul( _guid, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
String read_authkey(void) {
  int i, ii = 0;
  int eep_star = 341;
  int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
  for (i = eep_star; i < end_authkey + 16;  i = i + 1) {
      char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
void setup() {
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY, 1);
  delay(10);
  Serial.println(" ");
  pinMode(wificonfig_pin, INPUT_PULLUP);
  pinMode(led_pin,OUTPUT);
  EEPROM.begin(1024);
  if (EEPROM.read(300) != 60){initialConfig = true;}
  guid_authkey();
  if (WiFi.SSID()==""){ initialConfig = true;}
  mcp.begin();
  mcp.pinMode(0, OUTPUT);
  mcp.pinMode(1, OUTPUT);
  mcp.pinMode(2, OUTPUT);
  mcp.pinMode(3, OUTPUT);
  mcp.pinMode(4, OUTPUT);
  mcp.pinMode(5, OUTPUT);
  mcp.pinMode(6, OUTPUT);
  mcp.pinMode(7, OUTPUT);
  mcp.pinMode(8, OUTPUT);
  mcp.pinMode(9, OUTPUT);
  mcp.pinMode(10, OUTPUT);
  mcp.pinMode(11, OUTPUT);
  mcp.pinMode(12, OUTPUT);
  mcp.pinMode(13, OUTPUT);
  mcp.pinMode(14, OUTPUT);
  mcp.pinMode(15, OUTPUT);
  memset(btn, 0, sizeof(btn));
  btn[0].pin =1; EEPROM.get(400,btn[0].ms);Serial.print("initial_button_duration 0: ");Serial.println(btn[0].ms);
  btn[1].pin =2; EEPROM.get(410,btn[1].ms);Serial.print("initial_button_duration 1: ");Serial.println(btn[1].ms);
  btn[2].pin =3; EEPROM.get(420,btn[2].ms);Serial.print("initial_button_duration 2: ");Serial.println(btn[2].ms);
  btn[3].pin =4; EEPROM.get(430,btn[3].ms);Serial.print("initial_button_duration 3: ");Serial.println(btn[3].ms);
  btn[4].pin =5; EEPROM.get(440,btn[4].ms);Serial.print("initial_button_duration 4: ");Serial.println(btn[4].ms);
  btn[5].pin =6; EEPROM.get(450,btn[5].ms);Serial.print("initial_button_duration 5: ");Serial.println(btn[5].ms);
  btn[6].pin =7; EEPROM.get(460,btn[6].ms);Serial.print("initial_button_duration 6: ");Serial.println(btn[6].ms);
  btn[7].pin =8; EEPROM.get(470,btn[7].ms);Serial.print("initial_button_duration 7: ");Serial.println(btn[7].ms);
  btn[8].pin =9; EEPROM.get(480,btn[8].ms);Serial.print("initial_button_duration 8: ");Serial.println(btn[8].ms);
  btn[9].pin =10; EEPROM.get(490,btn[9].ms);Serial.print("initial_button_duration 9: ");Serial.println(btn[9].ms);
  btn[10].pin =11; EEPROM.get(500,btn[10].ms);Serial.print("initial_button_duration 10: ");Serial.println(btn[10].ms);
  btn[11].pin =12; EEPROM.get(510,btn[11].ms);Serial.print("initial_button_duration 11: ");Serial.println(btn[11].ms);
  btn[12].pin =13; EEPROM.get(520,btn[12].ms);Serial.print("initial_button_duration 12: ");Serial.println(btn[12].ms);
  btn[13].pin =14; EEPROM.get(530,btn[13].ms);Serial.print("initial_button_duration 13: ");Serial.println(btn[13].ms);
  btn[14].pin =15; EEPROM.get(540,btn[14].ms);Serial.print("initial_button_duration 14: ");Serial.println(btn[14].ms);
  btn[15].pin =16; EEPROM.get(550,btn[15].ms);Serial.print("initial_button_duration 15: ");Serial.println(btn[15].ms);
    supla_btn_init();
    eeprom_read_string(20, Supla_server, max_cr);Serial.print("Supla server: "); Serial.println(Supla_server);
    eeprom_read_string(105, Email, max_cr);Serial.print("Email: "); Serial.println(Email);
    eeprom_read_string(200, Supla_name, max_cr);Serial.print("Supla name: "); Serial.println(Supla_name);
   wifi_station_set_hostname(Supla_name);
      SuplaDevice.addRelay(100, false);
      SuplaDevice.addRelay(101, false);
      SuplaDevice.addRelay(102, false);
      SuplaDevice.addRelay(103, false);
      SuplaDevice.addRelay(104, false);
      SuplaDevice.addRelay(105, false);
      SuplaDevice.addRelay(106, false);
      SuplaDevice.addRelay(107, false);
      SuplaDevice.addRelay(108, false);
      SuplaDevice.addRelay(109, false);
      SuplaDevice.addRelay(110, false);
      SuplaDevice.addRelay(111, false);
      SuplaDevice.addRelay(112, false);
      SuplaDevice.addRelay(113, false);
      SuplaDevice.addRelay(114, false);
      SuplaDevice.addRelay(115, false);
      new Supla::Sensor::NormallyOpen(14, true);
      new Supla::Sensor::NormallyOpen(12, true);
      new Supla::Sensor::NormallyOpen(13, true);
      new Supla::Sensor::DS18B20(3);
    SuplaDevice.setName(Supla_name);
    SuplaDevice.setStatusFuncImpl(&status_func);
    wifi.enableSSL(false);
    SuplaDevice.begin(GUID,Supla_server,Email,AUTHKEY);
    for (int i = 0; i < 16; i++) {if ((EEPROM.read(i +100) == 1) && (btn[i].ms<10)){mcp.digitalWrite(i, HIGH);} }
void loop() {
  if (initialConfig == true){ondemandwifiCallback();}
  int C_W_read = digitalRead(wificonfig_pin);{
   if (C_W_read != last_C_W_state) {  time_last_C_W_change = millis();}
    if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       C_W_state = C_W_read;
       if (C_W_state == LOW) {
        ondemandwifiCallback () ;} } }
     last_C_W_state = C_W_read;
  SuplaDevice.iterate();
   delay(25);
    if (starting){
      httpUpdater.setup(&httpServer, "/update", "admin", "pass");
      httpServer.begin();
      starting = false;
     httpServer.handleClient();
   switch (s) {
    case 17:      // -----     STATUS_REGISTERED_AND_READY
     if (state10 == true){
        if (btn[i].ms<10){
         if (EEPROM.read(i +100) == 1){
          SuplaDevice.relayOn(i, 0);
      state10 = false;
     break;
    case 10:      // --------------------- REGISTER_IN_PROGRESS  ----------------------
     state10 = true;
     break;
  mcp_btn();
Posted: Thu Sep 24, 2020 7:38 pm
by pork
Hi,
my english is very, very bad, sorry :)
I have problem with compile project.
I must change relays board to low level triger :( and buttons to bistable,
Thanks for the help
