DirectLink remote control for Supla Thermostat
Everything indicates that I made the mistake and uploaded the wrong sketch (thermostat) and it caused errors. Now, I think everything will be ok. Once again, I'm sorry but this is my inattention. Now it updates nicely. Elmaya is a champion over a champion !!!
I'm glad it's finally fine.piomar2 wrote: ↑Thu Nov 07, 2019 6:58 pm Everything indicates that I made the mistake and uploaded the wrong sketch (thermostat) and it caused errors. Now, I think everything will be ok. Once again, I'm sorry but this is my inattention. Now it updates nicely. Elmaya is a champion over a champion !!!
It should work with all my software for Supla thermostats.
I welcome any suggestions for possible improvements.
I cannot configure the device to get the temperature values on the display.
"Link Temp - paste the DirectLink corresponding to the temperature channel." What should I enter from the obtained direct link from SUPLA website
https://svr41.supla.org/direct/837/W6SgrRUXgbxk89?
Pytam tylko jak muszę.
kotogi wrote: ↑Wed Sep 22, 2021 12:57 pm I cannot configure the device to get the temperature values on the display.
- Attachments
- wifimanager.jpg (21.71 KiB) Viewed 2231 times
I have a problem that the remote control does not display the set temperature (in its place is displayed -127) the direct link is certainly good because after switching the links to the temperature and the set temperature, the remote control correctly shows the set temperature (in place of the temperature).
When I put the link to the set temperature in both places, the remote control displays correctly both in the place of the temperature and the set temperature.
It seems to me that the reason for this behavior is too slow internet connection.
The question is whether it is not possible to change the server response timeouts to eliminate this.
mounted file system
reading config file
opened config file
104
{"Supla_server":"svr41.supla.org","D_Link_1":"/direct/846/Qa3EGQzS9HHiX","D_Link _2":"/direct/847/5bPrcodFAD","D_Link_3":"/direct/848/GAhQ7rxvbsp_XPN","Link_T":" /direct/849/BJzF__9WDhnXN","Link_T2":"/direct/852/9oPCZbbDjUFeTs"}
parsed json
Connected
Adres IP:
192.168.0.153 / 255.255.255.0 / 192.168.0.1
(RSSI): -68 dBm
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
reading config file
opened config file
104
parsed json
Connected
Adres IP:
(RSSI): -68 dBm
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
