thermostat with Oled display
you can use any resistors for the Gpio16 Pullup with a value between 2.2K and 100K
Is that relay active at a high level?
It looks a lot like those that don't work with Esp8266.
Should this set be powered separately or sufficient from a computer and a USB cable?
I uploaded soft, but nothing happens - the display is off, you can't see the chips in the wifi network.
Well, unless I loaded incorrectly ...
I have loaded one file called "supla_Termostst_oled_dimm_V04_DOUT_16Mbit". Do you still have to load any?
Settings below :
Settings below :
- Attachments
- termostat.jpg (221.04 KiB) Viewed 3392 times
Master, you're great.
The OLED display lit up .... and I didn't know that the file title was talking about settings - I'm doing this for the first time.
And for the future (a little after the topic of this post) - how do I know what to set in the window 0x0000, if not all softs have such a wonderful description as yours?
Our fun - probably in the evening.
Thank you.
This is how it looks now :
Thank you.
- Attachments
- 20200219_175457.jpg (2.21 MiB) Viewed 3388 times
