thermostat with settings from the Supla app
Posted: Fri Sep 13, 2019 10:51 am
in total 5 channels
channel 0 = automatic / manual thermostat
channel 1 = manual relay on / off
channel 2 = to the left the temperature decreases by 0.5º the right increases by 0.5º
channel 3 = temperature DS18B20
channel 4 = thermostat temperature
temperature and hysterysis are adjusted in wificonfig
temperature in x10 format (22º is written 220 in the configuration)
It can be changed from the app in 0.5º steps and will be stored
hysterisis in x10 format (+/- 1 is written 10 in the configuration)
Gpio
#define ONE_WIRE_BUS 2 //--------------------oneWire Dallas Temperature ----------
int relay_1 = 12; //------------------- automatic / manual Led ----- active high
int relay_2 = 13; //------------------- relay output ----- active high
int relay_3 = 120; //------------------- no Gpio -----
int button_1 = 4; //------------------- automatic / manual thermostat change ---- WiFi config 10 seconds --------
int button_2 = 5; //------------------- manual on / off ----
#define status_led 16 //------------------- status Led active low (on conecting / off conectet)
status_led:
flashing 1 second = no Wifi or connecting wifi.
flashing 0.2 seconds = wifi Config.
On = Wi-Fi connected, Supla not connected.
off = normal.
#include <FS.h> // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <math.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESPEFC.h> // modification of ESP8266HTTPUpdateServer that includes erases flash and wifi credentials
#include <Ticker.h> //for LED status
#include <OneWire.h>
extern "C"
#include "user_interface.h"
int relay_1 = 12; //------------------- thermometer on off Led ----- active high
int relay_3 = 120; //------------------- thermostat temperature setting +/- 0.5º no Gpio -----
int button_3 = 121; //------------------- No function ----
#define status_led 16 //------------------- status Led -----------------------
OneWire oneWire(ONE_WIRE_BUS);
DeviceAddress tempDeviceAddress;
Ticker ticker;
int resolution = 11;
bool pr_wifi = true;
bool start = true;
bool eep = LOW;
int epr = 0;
int s;
int an;
int buttonValue = 0;
int Term_Temp ;
int Term_Hist ;
double tr = -275;
unsigned long wifi_checkDelay = 20000;
unsigned long wifimilis;
unsigned long eep_milis;
unsigned long tr_milis;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000; // config delay 10 seconds ---------- opóźnienie konfiguracji 10 sekund
bool tikOn = false;
#define BTN_COUNT 3
WiFiClient client;
ESP8266WebServer httpServer(81);
ESPEFC httpUpdater;
const char* update_path = "/update";
char Supla_server[80];
char Location_id[15];
char Location_Pass[34];
char Supla_name[51];
char up_host[21];
char update_username[21];
char update_password[21];
char term_temp[5];
char term_hist[5];
byte mac[6];
bool initialConfig = false;
int timeout = 180; // seconds to run the wifi config
void tick(){
//toggle Led state
int state = digitalRead(status_led);
digitalWrite(status_led, !state);
void saveConfigCallback () { //callback notifying us of the need to save config
shouldSaveConfig = true;
ticker.attach( 0.2, tick);
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 80);
WiFiManagerParameter custom_Location_id("ID", "Location id", Location_id, 15);
WiFiManagerParameter custom_Location_Pass("Password", "Location Pass", Location_Pass, 34);
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
WiFiManagerParameter custom_up_host("up_host", "xxxx (DHCP name)", up_host, 21,"required");
WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
WiFiManagerParameter custom_term_temp("Termostat", "Temp x 10", term_temp, 5,"required");
WiFiManagerParameter custom_term_hist("Histerisis", "Histerisis x 10", term_hist, 5,"required");
WiFiManager wifiManager;
wifiManager.setBreakAfterConfig(true);
wifiManager.addParameter(&custom_Location_id);
wifiManager.addParameter(&custom_Location_Pass);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.addParameter(&custom_up_host);
wifiManager.addParameter(&custom_update_username);
wifiManager.addParameter(&custom_update_password);
wifiManager.addParameter(&custom_term_temp);
wifiManager.addParameter(&custom_term_hist);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setMinimumSignalQuality(8);
wifiManager.setConfigPortalTimeout(timeout);
if (!wifiManager.startConfigPortal("Supla_Termostat")) {
Serial.println("Not connected to WiFi but continuing anyway.");
} else {
Serial.println("connected...yeey :)"); //if you get here you have connected to the WiFi
//read updated parameters
strcpy(Location_id, custom_Location_id.getValue());
strcpy(Location_Pass, custom_Location_Pass.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
strcpy(up_host, custom_up_host.getValue());
strcpy(update_username, custom_update_username.getValue());
strcpy(update_password, custom_update_password.getValue());
strcpy(term_temp, custom_term_temp.getValue());
strcpy(term_hist, custom_term_hist.getValue());
WiFi.softAPdisconnect(true); // close AP
typedef struct { //------------------------------------------- BTN ----------------------------------------------------
int pin;
int relay_pin;
int channel;
char last_val;
int ms;
unsigned long last_time;
bool mem;
} _btn_t;
_btn_t btn[BTN_COUNT];
double t = -275;
switch(channelNumber)
case 3:
sensors.requestTemperatures();
t = sensors.getTempCByIndex(0);
if (t < -55){t = -275;}
break;
case 4:
double trd = (Term_Temp) ;
trd = (trd / 10) ;
t = (trd);
break;
return t;
void itrate_Term() {
tr = sensors.getTempCByIndex(0);
if (tr<-55){
if ( digitalRead(btn[1].relay_pin-1) == 1){
(btn[1].mem) = 0 ;
Serial.println(" Relay off temp to low");
SuplaDevice.relayOff(1);
return ;
double trt = (Term_Temp + Term_Hist) ;
trt = (trt / 10);
Serial.print("tr ");
Serial.println(tr);
if (tr >= trt) {
if ( digitalRead(btn[1].relay_pin-1) == 1) {
(btn[1].mem) = 0 ;
Serial.println(" Relay off ");
double trs = (Term_Temp - Term_Hist) ;
trs = (trs / 10) ;
if(tr <= trs) {
if ( digitalRead(btn[1].relay_pin-1) == 0) {
(btn[1].mem) = 1 ;
Serial.println(" Relay on ");
SuplaDevice.relayOn(1, 0);
void supla_timer() {
char v;
unsigned long now = millis();
for(int a=0;a<2;a++)
if (btn[a].pin > 0) {
v = digitalRead(btn[a].pin-1);
if (v != btn[a].last_val && now - btn[a].last_time ) {
btn[a].last_val = v;
btn[a].last_time = now;
delay(75);
if (v==0)
if ( btn[a].ms > 0 ) {
SuplaDevice.relayOn(btn[a].channel, btn[a].ms);
Serial.println(" monostable");
} else {
if ( (btn[a].mem) == 1 ) {
SuplaDevice.relayOff(btn[a].channel);
Serial.print("BTN Switsh off relay ");
Serial.println(btn[a].relay_pin-1);
} else {
SuplaDevice.relayOn(btn[a].channel, 0);
Serial.print("BTN Switsh on relay ");
void supla_btn_init() {
for(int a=0;a<BTN_COUNT;a++)
pinMode(btn[a].pin-1, INPUT_PULLUP);
btn[a].last_val = digitalRead(btn[a].pin-1);
btn[a].last_time = millis();
pinMode(btn[a].relay_pin-1,OUTPUT);
int supla_DigitalRead(int channelNumber, uint8_t pin) {
return btn[channelNumber].mem;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
btn[channelNumber].mem =val;
case 0:
if ( (btn[channelNumber].mem) == 0 ) {
Serial.print("Manual Mode ");
digitalWrite(btn[channelNumber].relay_pin-1, LOW);
eep_milis = millis() + 2000 ;
}else {
Serial.print("Auto Mode ");
digitalWrite(btn[channelNumber].relay_pin-1, HIGH);
break;
case 1:
Serial.print("Switsh off relay ");
Serial.println(btn[channelNumber].relay_pin-1);
}else {
Serial.print("Switsh on relay ");
break;
case 2:
Serial.print("Temp - ");
Term_Temp = Term_Temp - 5 ;
Serial.println(Term_Temp);
tr_milis = millis() + 5000 ;
}else {
Serial.print("Temp + ");
Term_Temp = Term_Temp + 5 ;
trd = (trd / 10) ;
SuplaDevice.channelDoubleValueChanged(4,trd);
break;
return;
void Eeprom_save() { //----------EEPROM write ---------------------- EEprom
if (start){
return;
if ( (btn[0].mem) == 0 ) {
for(int e=0;e<BTN_COUNT;e++) {
if ( btn[e].ms > 0 ) {
continue;
} else {
eep = (btn[e].mem); // --- read relay state
if (eep != EEPROM.read(e)){ // --- compare relay state with memorized state
EEPROM.write(e,eep); // --- if different write memory
Serial.print("EEPROM.");
Serial.print(e);
Serial.print(" write.");
Serial.print((eep));
Serial.print(" channel ");
Serial.println((btn[e].channel));
EEPROM.commit();
if ( (btn[0].mem) == 1 ) {
eep = (btn[0].mem); // --- read relay state
if (eep != EEPROM.read(0)){ // --- compare relay state with memorized state
EEPROM.write(0,eep); // --- if different write memory
Serial.print(0);
Serial.println((btn[0].channel));
EEPROM.commit();
void Eepron_read() { //----------EEPROM read ---------------------- EEprom
if ( btn[epr].ms > 0 ) {
return;
} else {
eep = EEPROM.read(epr); // ---read relay state
Serial.print(epr);
Serial.print(" read.");
Serial.println((btn[epr].channel));
if (eep == HIGH){ // --- if 1 send relay on
(btn[epr].mem) = 1 ;
SuplaDevice.relayOn(epr, 0); // --- only one channel on each pass
if (eep == 1) {
bool stat = digitalRead(btn[1].relay_pin-1);
if (stat) SuplaDevice.relayOn(1, 0);
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
s=status; // -- to check if we are registered and ready before restore from memory
void setup() { //------------------------------------------------ Setup ----------------------------------------------
wifi_set_sleep_type(NONE_SLEEP_T);
Serial.begin(115200);
delay(200);
pinMode(status_led,OUTPUT);
ticker.attach( 1.0, tick);
EEPROM.begin(512);
sensors.begin();
sensors.getAddress(tempDeviceAddress, 0);
sensors.setResolution(tempDeviceAddress, resolution);
sensors.setWaitForConversion(false);
if (WiFi.SSID()==""){
initialConfig = true;
Serial.println("initial config");
//read configuration from FS json
Serial.println("mounting FS...");
WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
uint8_t mac[WL_MAC_ADDR_LENGTH];
WiFi.macAddress(mac);
char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
SuplaDevice.addRelay(101, false);
SuplaDevice.addRelay(102, false);
SuplaDevice.addRelay(103, false);
memset(btn, 0, sizeof(btn));
btn[0].pin =button_1 +1; // pin gpio buton +1
btn[0].relay_pin =relay_1 +1; // pin gpio Relay +1
btn[0].channel =0; // channel
btn[0].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[0].mem =0;
btn[1].pin =button_2 +1; // pin gpio buton +1
btn[1].relay_pin =relay_2 +1; // pin gpio Relay +1
btn[1].channel =1; // channel
btn[1].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[1].mem =0;
btn[2].pin =button_3 +1; // pin gpio buton +1
btn[2].relay_pin =relay_3 +1; // pin gpio Relay +1
btn[2].channel =2; // channel
btn[2].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[2].mem =0;
supla_btn_init();
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
DynamicJsonBuffer jsonBuffer;
json.printTo(Serial); //print config data to serial on startup
if (json.success()) {
Serial.println("\nparsed json");
strcpy(Location_id, json["Location_id"]);
strcpy(Location_Pass, json["Location_Pass"]);
strcpy(Supla_name, json["Supla_name"]);
strcpy(up_host, json["up_host"]);
strcpy(update_username, json["update_username"]);
strcpy(update_password, json["update_password"]);
strcpy(term_temp, json["term_temp"]);
Term_Temp = (String(term_temp).toInt());
strcpy(term_hist, json["term_hist"]);
Term_Hist = (String(term_hist).toInt());
} else {
Serial.println("failed to load json config");
} else {
Serial.println("failed to mount FS");
wifi_station_set_hostname(up_host); //nazwa w sieci lokalnej @cino111
SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead); // ------Send Value to server -------
SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite); // ------- Read Value from server -------
SuplaDevice.setTimerFuncImpl(&supla_timer);
SuplaDevice.setStatusFuncImpl(&status_func); // ----------------------------- Status -----------------------------
SuplaDevice.setName(Supla_name);
int LocationID = atoi(Location_id);
mac, // Ethernet MAC address
Supla_server, // SUPLA server address
LocationID, // Location ID
Location_Pass); // Location Password
void loop() {
if (start){
// read_initial_relay_state
for(int i=0;i<BTN_COUNT;i++){ // ---check relay except der have delay (staircase)
if ( (btn[i].ms) > 0 ) {
digitalWrite(btn[i].relay_pin-1, LOW);
continue;
} else {
eep = EEPROM.read(i);
if (eep >= 2 ){
EEPROM.write(i,0);
Serial.println("epp correct");
EEPROM.commit();
Serial.print("Recover.");
Serial.print(i);
Serial.println((btn[i].channel));
btn[i].mem =eep;
Serial.print((btn[i].relay_pin) -1);
Serial.print(" set ");
Serial.println(eep);
start = false;
if (initialConfig){
EEPROM.write(i, 0);
EEPROM.commit();
Serial.println("initial config triger");
ondemandwifiCallback () ;
if (shouldSaveConfig) {
Serial.println("saving config");
json["Location_id"] = Location_id;
json["Location_Pass"] = Location_Pass;
json["Supla_name"] = Supla_name;
json["up_host"] = up_host;
json["update_username"] = update_username;
json["update_password"] = update_password;
json["term_temp"] = term_temp;
json["term_hist"] = term_hist;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
ticker.detach();
digitalWrite(status_led, HIGH);
ESP.restart();
delay(5000);
if (WiFi.status() != WL_CONNECTED) {
WiFi_up();
if (millis() > eep_milis){
Eeprom_save() ; // ------------------------------Eepron save callback -----------------------------
eep_milis = millis() + 5000 ;
switch (s) { // ------------------------------------------------ Status ------------------------------------
case 17: // ----- STATUS_REGISTERED_AND_READY
if (epr<2){
Eepron_read() ; // ------------------------------- Eeprom read callback -------------------------------
epr = epr+1;// -------- 1 loop for each output ----------
if (tikOn == true){
ticker.detach();
tikOn = false;
Serial.println("supla.Ready");}
break;
case 10: // --------------------- REGISTER_IN_PROGRESS ----------------------
epr = 0 ;
break;
int C_W_read = digitalRead(btn[0].pin-1);{
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
Serial.println("Triger sate changed");
C_W_state = C_W_read;
if (C_W_state == LOW) {
//ondemandwifiCallback () ;
WiFi.disconnect(true);
ESP.eraseConfig();
ESP.reset();
last_C_W_state = C_W_read;
SuplaDevice.iterate();
if (pr_wifi == true){
Serial.println("");
Serial.println("CONNECTED");
Serial.print("local IP: ");
Serial.print("subnetMask: ");
Serial.print("gatewayIP: ");
long rssi = WiFi.RSSI();
Serial.print("Signal Strength (RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
pr_wifi = false;
httpUpdater.setup(&httpServer, update_path, update_username, update_password);
httpServer.begin();
ticker.detach();
digitalWrite(status_led, LOW);
delay(100);
httpServer.handleClient();
if (millis() > tr_milis){
if ((btn[0].mem) == true) itrate_Term(); // ------------------------------Termostat callback -----------------------------
if ((String(term_temp).toInt()) != Term_Temp){
double trs = (Term_Temp) ;
trs = (trs / 10) ;
Serial.println(term_temp);
Serial.println("save Temp_Term");
itoa(Term_Temp ,term_temp ,10) ;
// --------------------------save fs ----------------------------------------
if (!configFile) {
configFile.close();
// Supla.org ethernet layer
if ( size > 0 ) {
return -1;
return client.connected();
client.stop();
WiFi_up();
SuplaDeviceCallbacks cb;
cb.get_temperature = &get_temperature;
//cb.get_temperature = NULL;
cb.get_rgbw_value = NULL;
cb.set_rgbw_value = NULL;
return cb;
void WiFi_up(){ // conect to wifi
if (millis() > wifimilis) {
WiFi.begin();
pr_wifi = true;
tikOn = true;
wifimilis = (millis() + wifi_checkDelay) ;
Serial.println("CONNECTING WIFI");
