Hello,
does this additional D5 relay work? Anyone installing? On my Nodemcu, the thermostat works OK, and this additional one does not respond at all ... I uploaded the finished @elmaja file and it also does not work.
Regards
thermostat with settings from the Supla app
Can't you see the channel in the App?
do you see it but it doesn't change?
The relay channel is visible in Supla, it just doesn't switch.
Nodemcu is OK after replacing Gpio, the thermostat works correctly also on the second output.
Hi Elmaya
Can you share your SuplaDevice library
I try compile but it give error:
b.r.
Kris
'class SuplaDeviceClass' has no member named 'channelDoubleValueChanged'
Kris
POW_R2 x2 ■SP111 x3
POW_R2 x2 ■SP111 x3
is the usual Supla 1.6.1 library.kris.sg wrote: ↑Wed Mar 25, 2020 4:58 pm Hi Elmaya
I try compile but it give error:b.r.Code: Select all
Kris
https://github.com/SUPLA/arduino
thx for the help
i replace supladevice lib but there is another problem:
In file included from C:\Users\Kris\Documents\Arduino\Supla_termostat\supla_termostat.ino:11:0:
C:\Users\Kris\Documents\Arduino\libraries\ESPEFC-master\src/ESPEFC.h:4:7: error: using typedef-name 'using ESP8266WebServer = class esp8266webserver::ESP8266WebServerTemplate<WiFiServer>' after 'class'
class ESP8266WebServer;
In file included from C:\Users\Kris\Documents\Arduino\libraries\WiFiManager/WiFiManager.h:48:0,
from C:\Users\Kris\Documents\Arduino\Supla_termostat\supla_termostat.ino:7:
C:\Users\Kris\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:229:80: note: 'using ESP8266WebServer = class esp8266webserver::ESP8266WebServerTemplate<WiFiServer>' has a previous declaration here
using ESP8266WebServer = esp8266webserver::ESP8266WebServerTemplate<WiFiServer>;
exit status 1
Błąd kompilacji dla płytki Generic ESP8266 Module.
POW_R2 x2 ■SP111 x3
POW_R2 x2 ■SP111 x3
If you read attentively the first line of the code you will see ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth.kris.sg wrote: ↑Thu Mar 26, 2020 9:44 am thx for the help
i replace supladevice lib but there is another problem:Code: Select all
In file included from C:\Users\Kris\Documents\Arduino\Supla_termostat\supla_termostat.ino:11:0: C:\Users\Kris\Documents\Arduino\libraries\ESPEFC-master\src/ESPEFC.h:4:7: error: using typedef-name 'using ESP8266WebServer = class esp8266webserver::ESP8266WebServerTemplate<WiFiServer>' after 'class' class ESP8266WebServer; ^ In file included from C:\Users\Kris\Documents\Arduino\libraries\WiFiManager/WiFiManager.h:48:0, from C:\Users\Kris\Documents\Arduino\Supla_termostat\supla_termostat.ino:7: C:\Users\Kris\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:229:80: note: 'using ESP8266WebServer = class esp8266webserver::ESP8266WebServerTemplate<WiFiServer>' has a previous declaration here using ESP8266WebServer = esp8266webserver::ESP8266WebServerTemplate<WiFiServer>; ^ exit status 1 Błąd kompilacji dla płytki Generic ESP8266 Module.
you have 2.6.2 (change it).
attached ESPEFC library
now everything is ok
thx Elmaya
my mystake, I thought there might be a higher version board manager
thx Elmaya
POW_R2 x2 ■SP111 x3
POW_R2 x2 ■SP111 x3
Is it possible for the author to expand the thermostat with cooling functions? So that the thermostat can choose the heating / cooling mode.
Currently the thermostat has turned on if the temperature drops below the one set on the thermostat and will turn off if the temperature reaches the set temperature.
I need the thermostat to turn on if the temperature on the DS18B20 sensor reaches a higher level than the setpoint and to turn off if the temperature on the sensor drops below the setpoint.
