Esp8266 12 touch control relay
elmaya
Wed Mar 27, 2019 12:27 pm
Esp8266 12 relay 12 touch buttons with memory in case of lack of power and operates without internet connection
esp8266
Gpio 5(D1) -- SCL
Gpio 4(D2) -- SDA
Gpio 2(D4) -- Led (turn on when some sensor is touched)
Mcp23017
in VCC -- +3.3
in Gnd-a0-a1-a2 --GND
SCL -- esp Gpio 5(D1)
SDA -- esp Gpio 4(D2)
Gpio A0 -- Out 1
Gpio A1 -- Out 2
Gpio A2 -- Out 3
Gpio A3 -- Out 4
Gpio A4 -- Out 5
Gpio A5 -- Out 6
Gpio A6 -- Out 7
Gpio A7 -- Out 8
Gpio B0 -- Out 9
Gpio B1 -- Out 10
Gpio B2 -- Out 11
Gpio B3 -- Out 12
Mpr121
in VCC -- +3.3
in Gnd --GND
0-11 -- touch sensor
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <Adafruit_MCP23017.h>
#include <math.h>
#include <Adafruit_MPR121.h>
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h> //--------- https://github.com/tzapu/WiFiManager/tree/0.14 -------------
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <DoubleResetDetector.h>
extern "C"
#include "user_interface.h"
#define DRD_TIMEOUT 30 // Number of seconds after reset during which a  subseqent reset will be considered a double reset.
#define DRD_ADDRESS 0 // RTC Memory Address for the DoubleResetDetector to use
#define onboard_led 2  //D4 MPR121 active
DoubleResetDetector drd(DRD_TIMEOUT, DRD_ADDRESS);
int uno = 1;
bool pr_wifi = false;
bool start = true;
bool eep = LOW;          //             ---------------- Eeprom ------------------
int epr = 0;             //             ----------- Eepron read loops ------------
int s;                   //             ---------------- Status ------------------
uint8_t an;
int buttonValue = 0;
unsigned long wifi_checkDelay = 60000;  // wifi reconect delay
unsigned long wifimilis;
unsigned long eep_milis;
unsigned long an_milis;
#define BEGIN_PIN 100
#define BTN_COUNT 12
#ifndef _BV
#define _BV(bit) (1 << (bit))
#endif
Adafruit_MCP23017 mcp;
// You can have up to 4 on one i2c bus but one is enough for testing!
Adafruit_MPR121 cap = Adafruit_MPR121();
// Keeps track of the last pins touched
// so we know when buttons are 'released'
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
WiFiClient client;
char Supla_server[40];
char Location_id[15];
char Location_Pass[20];
byte mac[6];
//flag for saving data
bool initialConfig = false;
int timeout           = 120; // seconds to run for wifi config
void saveConfigCallback () {                 //callback notifying us of the need to save config
  shouldSaveConfig = true;
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 40);
  WiFiManagerParameter custom_Location_id("ID", "Location_id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location_Pass", Location_Pass, 20);
  WiFiManager wifiManager;
  wifiManager.setBreakAfterConfig(true);
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  wifiManager.setMinimumSignalQuality();
    wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("Supla_MPR121")) {
      Serial.println("Not connected to WiFi but continuing anyway.");
    } else {
      Serial.println("connected...yeey :)");    //if you get here you have connected to the WiFi
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
  WiFi.softAPdisconnect(true);   //  close AP
typedef struct {  //------------------------------------------- BTN ----------------------------------------------------
  int pin;
  int relay_pin;
  int channel;
  char last_val;
  int ms;
  unsigned long last_time;
  bool mem;
} _btn_t;
_btn_t btn[BTN_COUNT];
void supla_timer() {
  char v;
  unsigned long now = millis();
  for(int a=0;a<BTN_COUNT;a++)
    if (btn[a].pin > 0) {
        v = digitalRead(btn[a].pin);
        if (v != btn[a].last_val && now - btn[a].last_time ) {
           btn[a].last_val = v;
           btn[a].last_time = now;
           if (v==0)
              if ( btn[a].ms > 0 ) {
                     SuplaDevice.relayOn(btn[a].channel, btn[a].ms);
                     Serial.println(" monostable");
                 } else {
                 if ( (btn[a].mem) == 1 ) {   //   ----------------- == 1 if channel is false... == 0 if channel is true -----------------------
                  SuplaDevice.relayOff(btn[a].channel);
                  Serial.print("BTN Switsh off relay ");
                  Serial.println(btn[a].relay_pin);
                 } else {
                  SuplaDevice.relayOn(btn[a].channel, 0);
                  Serial.print("BTN Switsh on relay ");
void supla_btn_init() {
        pinMode(btn[a].pin, INPUT_PULLUP);
        btn[a].last_val = digitalRead(btn[a].pin);
        btn[a].last_time = millis();
int supla_DigitalRead(int channelNumber, uint8_t pin) {
      if (channelNumber == 0){
        if (btn[0].mem ==0) return 0;
        else return 1;
      if (channelNumber == 1){
        if (btn[1].mem ==0) return 0;
        else return 1;
      if (channelNumber == 2){
        if (btn[2].mem ==0) return 0;
        else return 1;
      if (channelNumber == 3){
        if (btn[3].mem ==0) return 0;
        else return 1;
      if (channelNumber == 4){
        if (btn[4].mem ==0) return 0;
        else return 1;
      if (channelNumber == 5){
        if (btn[5].mem ==0) return 0;
        else return 1;
      if (channelNumber == 6){
        if (btn[6].mem ==0) return 0;
        else return 1;
      if (channelNumber == 7){
        if (btn[7].mem ==0) return 0;
        else return 1;
      if (channelNumber == 8){
        if (btn[8].mem ==0) return 0;
        else return 1;
      if (channelNumber == 9){
        if (btn[9].mem ==0) return 0;
        else return 1;
      if (channelNumber == 10){
        if (btn[10].mem ==0) return 0;
        else return 1;
      if (channelNumber == 11){
        if (btn[11].mem ==0) return 0;
        else return 1;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {  //------------------------------------------------  Virtual ----------------------------
       btn[0].mem =val;
       mcp.digitalWrite(0, val);
       btn[1].mem =val;
       mcp.digitalWrite(1, val);
       btn[2].mem =val;
       mcp.digitalWrite(2, val);
       btn[3].mem =val;
       mcp.digitalWrite(3, val);
       btn[4].mem =val;
       mcp.digitalWrite(4, val);
       btn[5].mem =val;
       mcp.digitalWrite(5, val);
       btn[6].mem =val;
       mcp.digitalWrite(6, val);
       btn[7].mem =val;
       mcp.digitalWrite(7, val);
       btn[8].mem =val;
       mcp.digitalWrite(8, val);
       btn[9].mem =val;
       mcp.digitalWrite(9, val);
       btn[10].mem =val;
       mcp.digitalWrite(10, val);
       btn[11].mem =val;
       mcp.digitalWrite(11, val);
  return;
void Eeprom_save() {                  //----------EEPROM write  ---------------------- EEprom
        if (start){
          return;
      for(int i=0;i<BTN_COUNT;i++) {  //  ---check relay except it have delay (staircase)
         if ( btn[i].ms > 0 ) {
                     continue;
         } else {
        eep = (btn[i].mem);                    //  --- read relay state
        if (eep != EEPROM.read(i)){            //  --- compare relay state with memorized state
         EEPROM.write(i,eep);                  //  --- if different write memory
         Serial.print("EEPROM.");
         Serial.print(i);
         Serial.print(" write.");
         Serial.print((eep));
         Serial.print(" channel ");
         Serial.println((btn[i].channel));
         EEPROM.commit();
void Eepron_read() {                  //----------EEPROM read  ---------------------- EEprom
        eep = EEPROM.read(epr);               //  ---read relay state
         Serial.print(epr);
         Serial.print(" read.");
         Serial.println((btn[epr].channel));
        if (eep == HIGH){                    //  --- if 1 send relay on
          SuplaDevice.relayOn(epr, 0);       //  --- only one channel in each pass
void status_func(int status, const char *msg) {     //    ------------------------ Status --------------------------
 s=status;                                          //    -- to check if we are registered and ready before restore from memory
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200);
  //Wire.begin(0,10);
  EEPROM.begin(512);
  mcp.begin();      // use default address 0
  mcp.pinMode(0, OUTPUT);
  mcp.pinMode(1, OUTPUT);
  mcp.pinMode(2, OUTPUT);
  mcp.pinMode(3, OUTPUT);
  mcp.pinMode(4, OUTPUT);
  mcp.pinMode(5, OUTPUT);
  mcp.pinMode(6, OUTPUT);
  mcp.pinMode(7, OUTPUT);
  mcp.pinMode(8, OUTPUT);
  mcp.pinMode(9, OUTPUT);
  mcp.pinMode(10, OUTPUT);
  mcp.pinMode(11, OUTPUT);
  pinMode(onboard_led, OUTPUT);
  digitalWrite(onboard_led, HIGH);
  if (!cap.begin(0x5A)) {
    Serial.println("MPR121 not found, check wiring?");
    while (1);
  Serial.println("MPR121 found!");
  if (WiFi.SSID()==""){  //Serial.println("We haven't got any access point credentials, so get them now");
    initialConfig = true;
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        DynamicJsonBuffer jsonBuffer;
        //json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(Location_id, json["Location_id"]);
          strcpy(Location_Pass, json["Location_Pass"]);
        } else {
          Serial.println("failed to load json config");
      } else {
        Serial.println("failed to mount FS");
   if (drd.detectDoubleReset()) {
    Serial.println("Double Reset Detected");
    ondemandwifiCallback ();
  } else {
    Serial.println("No Double Reset Detected");
   WiFi.mode(WIFI_STA);
   uint8_t mac[WL_MAC_ADDR_LENGTH];
   WiFi.macAddress(mac);
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
  SuplaDevice.addRelay(101, false);
  SuplaDevice.addRelay(102, false);
  SuplaDevice.addRelay(103, false);
  SuplaDevice.addRelay(104, false);
  SuplaDevice.addRelay(105, false);
  SuplaDevice.addRelay(106, false);
  SuplaDevice.addRelay(107, false);
  SuplaDevice.addRelay(108, false);
  SuplaDevice.addRelay(109, false);
  SuplaDevice.addRelay(110, false);
  SuplaDevice.addRelay(111, false);
  SuplaDevice.addRelay(112, false);
  memset(btn, 0, sizeof(btn));
  btn[0].pin =22;          // pin gpio buton  0 = no buton
  btn[0].relay_pin =101;  // pin gpio Relay
  btn[0].channel =0;      // channel
  btn[0].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[0].mem =0;
  btn[1].pin =22;          // pin gpio buton  0 = no buton
  btn[1].relay_pin =102;  // pin gpio Relay
  btn[1].channel =1;      // channel
  btn[1].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[1].mem =0;
  btn[2].pin =22;          // pin gpio buton  0 = no buton
  btn[2].relay_pin =103;  // pin gpio Relay
  btn[2].channel =2;      // channel
  btn[2].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[2].mem =0;
  btn[3].pin =22;         // pin gpio buton  0 = no buton
  btn[3].relay_pin =104;  // pin gpio Relay
  btn[3].channel =3;      // channel
  btn[3].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[3].mem =0;
  btn[4].pin =22;         // pin gpio buton  0 = no buton
  btn[4].relay_pin =105;  // pin gpio Relay
  btn[4].channel =4;      // channel
  btn[4].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[4].mem =0;
  btn[5].pin =22;         // pin gpio buton  0 = no buton
  btn[5].relay_pin =106;  // pin gpio Relay
  btn[5].channel =5;      // channel
  btn[5].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[5].mem =0;
  btn[6].pin =22;         // pin gpio buton  0 = no buton
  btn[6].relay_pin =107;    // pin gpio Relay
  btn[6].channel =6;      // channel
  btn[6].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[6].mem =0;
  btn[7].pin =22;          // pin gpio buton  0 = no buton
  btn[7].relay_pin =108;  // pin gpio Relay
  btn[7].channel =7;      // channel
  btn[7].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[7].mem =0;
  btn[8].pin =22;          // pin gpio buton  0 = no buton
  btn[8].relay_pin =109;  // pin gpio Relay
  btn[8].channel =8;      // channel
  btn[8].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[8].mem =0;
  btn[9].pin =22;          // pin gpio buton  0 = no buton
  btn[9].relay_pin =110;  // pin gpio Relay
  btn[9].channel =9;      // channel
  btn[9].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[9].mem =0;
  btn[10].pin =22;          // pin gpio buton  0 = no buton
  btn[10].relay_pin =111;  // pin gpio Relay
  btn[10].channel =10;      // channel
  btn[10].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[10].mem =0;
  btn[11].pin =22;         // pin gpio buton  0 = no buton
  btn[11].relay_pin =112;  // pin gpio Relay
  btn[11].channel =11;      // channel
  btn[11].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[11].mem =0;
  SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead);    //            ------Send Value to server -------
  SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite);   //        -------  Read Value from server   -------
  SuplaDevice.setTimerFuncImpl(&supla_timer);
  SuplaDevice.setStatusFuncImpl(&status_func);    //   ----------------------------- Status -----------------------------
  SuplaDevice.setName("Supla_MPR121");
  int LocationID = atoi(Location_id);
                    Supla_server,      // SUPLA server address
                    LocationID,        // Location ID
                    Location_Pass);    // Location Password
void loop() {
  drd.loop();
  if (start){
    // read_initial_relay_state
    for(int i=0;i<BTN_COUNT;i++){      //  ---check relay except der have delay (staircase)
     if ( (btn[i].ms) > 0 ) {
                     continue;
         } else {
        eep = EEPROM.read(i);               //  ---read relay state
       if (eep > uno ){
         EEPROM.write(i,0);
         Serial.println("epp correct");
         EEPROM.commit();
         Serial.print("Recover.");
         Serial.print(i);
         btn[i].mem =eep;
         mcp.digitalWrite(btn[i].channel, eep);// set single pin
    start = false;
  if (initialConfig){
                     continue;
     } else {
        EEPROM.write(i,0);
    ondemandwifiCallback () ;
  if (shouldSaveConfig) {
    Serial.println("saving config");
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    ESP.restart();
    delay(5000);
  if (WiFi.status() != WL_CONNECTED) {
    WiFi_up();
    pr_wifi = true;
  else if ((WiFi.status() == WL_CONNECTED)  && (pr_wifi)){
    Serial.println("");
    Serial.println("CONNECTED");
    Serial.print("local IP: ");
    Serial.print("subnetMask: ");
    Serial.print("gatewayIP: ");
    long rssi = WiFi.RSSI();
    Serial.print("Signal Strength (RSSI): ");
    Serial.print(rssi);
    Serial.println(" dBm");
    pr_wifi = false;
  SuplaDevice.iterate();
  MPR121_switch();
  if (millis() > eep_milis){
     Eeprom_save() ;   //        ------------------------------Eepron save callback -----------------------------
     eep_milis = eep_milis + 5000 ;
  switch (s) {    //    ------------------------------------------------ Status ------------------------------------
    case 17:      // -----     STATUS_REGISTERED_AND_READY
    if (epr<BTN_COUNT){
     Eepron_read() ;                // ------------------------------- Eeprom read callback -------------------------------
     epr = epr+1;                   // -------- 1 loop for each output ----------
    break;
    case 10:      // --------------------- REGISTER_IN_PROGRESS  ----------------------
    epr = 0 ;
    break;
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
       WiFi_up();
          SuplaDeviceCallbacks cb;
          cb.get_temperature = NULL;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
void WiFi_up(){ // conect to wifi
 unsigned long ahora = millis();
  if (ahora >= wifimilis)  {
  Serial.println("CONNECTING WIFI");
  WiFi.begin();
  wifimilis = (millis() + wifi_checkDelay) ;
void MPR121_switch(){
  // Get the currently touched pads
  currtouched = cap.touched();
  yield();
  for (uint8_t i=0; i<12; i++) {
    // it if *is* touched and *wasnt* touched before, alert!
    if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
      Serial.print(i); Serial.println(" touched");
      yield();
      if ((i) == 0 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 1 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 2 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 3 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 4 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 5 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 6 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 7 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 8 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 9 ){  an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 10 ){ an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
      if ((i) == 11 ){ an = (i); MPR121Relay() ; digitalWrite(onboard_led, LOW); }
    // if it *was* touched and now *isnt*, alert!
    if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
      Serial.print(i); Serial.println(" released");
  // reset our state
  lasttouched = currtouched;
  delay (50);
void MPR121Relay(){
   if ( btn[an].ms > 0 ) {
                     SuplaDevice.relayOn(btn[an].channel, btn[an].ms);
                 } else {
                 if ( (btn[an].mem) == 1 ) {   //   ----------------- == 1 if channel is false... == 0 if channel is true -----------------------
                  SuplaDevice.relayOff(btn[an].channel);
                  Serial.println(btn[an].relay_pin);
                 } else {
                  SuplaDevice.relayOn(btn[an].channel, 0);
             delay (50);
// CFG MODE - SWITCH
To bring the device into configuration mode, in this case press Reset_Button 2 times
When in configuration mode, the device goes into Access Point mode.
In order to enter or change the settings, you need to:
- Sign in at https://cloud.supla.org (registration is free of charge)
- Connect to WiFi called "Supla_MPR121” from any computer with a wireless network card and Internet browser.
- Open access page: http://192.168.4.1
- Enter user name and password to the WiFi through which the device will get Internet access.
- Enter Server address, Location ID and Location Password, which will be provided once you sign in at cloud.supla.org
supla_23017_MRP121_DOUT_16Mbit.rar
compiled firmware
(1.26 MiB) Downloaded 117 times
peterson13
Thu Mar 28, 2019 6:48 am
Well done! :idea:
selo
Wed Dec 18, 2019 1:02 am
Does not work for me. Can you give arduino sketch file. Thanks.
elmaya
Wed Dec 18, 2019 8:00 am
it works perfectly. :lol:
I use every day, check your connections.
selo
Wed Dec 18, 2019 9:46 am
Of course it's works perfectly :). I'm making a mistake somewhere.
My wemos d1 goes not to accesspoint mode after i press reset button 2 times, it blinks every 2 seconds. I have tested with other wemos, same problem. I have checked wirings and not see any error. In arduino serial monitor it prints following:
Soft WDT reset
ctx: cont
sp: 3ffffd50 end: 3fffffd0 offset: 01b0
>>>stack>>>
3fffff00:  3fff0c04 0000001f 3fff0c04 40213668
3fffff10:  3fff0c04 3ffefd68 3fff0c04 40213885
3fffff20:  3ffe93c0 3ffefd64 00000000 40213885
3fffff30:  3ffe9274 00000001 3fff0c04 402138b0
3fffff40:  3fff0c04 0000005a 3fff0c04 40213924
3fffff50:  4020912f 3ffefd68 3fff0c04 402091f1
3fffff60:  feefeffe feefeffe feefeffe feefeffe
3fffff70:  feefeffe feefeffe feefeffe feefeffe
3fffff80:  feefeffe feefeffe feefeffe feefeffe
3fffff90:  feefeffe feefeffe feefeffe feefeffe
3fffffa0:  feefeffe feefeffe feefeffe 3fff0cdc
3fffffb0:  3fffdad0 00000000 3fff0cd4 402148f0
3fffffc0:  feefeffe feefeffe 3ffe8650 40100739
<<<stack<<<
 ets Jan  8 2013,rst cause:1, boot mode:(3,7)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
⸮MPR121 not found, check wiring?
Can you help me. Thanks.
elmaya
Wed Dec 18, 2019 11:52 am
clearly describes Mpr121 not found.
what model of Mpr121 you are using, maybe an image of the module.
selo
Wed Dec 18, 2019 12:01 pm
This one:
elmaya
Wed Dec 18, 2019 12:19 pm
ADD connected to ground?
has to be
selo
Wed Dec 18, 2019 3:24 pm
has to be
Yes, ADD is with GND 0 Ohm.
Can the wemos go to access point mode without attachting to mpr21 and mcp23017?
elmaya
Wed Dec 18, 2019 3:26 pm
has to be
no
Post Reply
