Page 9 of 12
Re: Supla Button 4 direct links
Posted: Mon Dec 16, 2019 11:26 pm
by szym3k
i have 4443 (docker).
192.168.1.9:4443
when i get link in browser:
I modified the code under 4443
#include <FS.h>
#include <WiFiClientSecure.h>
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <Ticker.h>      //for LED status
Ticker ticker;
const char* host = "";
const int httpsPort = 4443;
// Use web browser to view and copy
// SHA1 fingerprint of the certificate
const char* fingerprint = "41 06 13 c7 8d 0c 66 2b 79 32 5d 1e a4 2e dc 7a ae 6d 3c 7b";
//define your default values here, if there are different values in config.json, they are overwritten.
//length should be max size + 1
char Supla_server[40];
char D_Link_1[40];
char D_Link_2[40];
char D_Link_3[40];
char D_Link_4[40];
byte mac[6];
String url = "/direct/xx/xxxxxxxxx/read";
//flag for saving data
bool initialConfig = false;
#define onboard_led D4
#define TRIGGER_PIN D3    // wifi config
#define Link_1_PIN D5     // triger Link 1
#define Link_2_PIN D6     // triger Link 2
#define Link_3_PIN D1     // triger Link 3
#define Link_4_PIN D2     // triger Link 4
int timeout           = 120; // seconds to run for
void tick()
  //toggle state
  int state = digitalRead(onboard_led);  // get the current state of D4 pin
  digitalWrite(onboard_led, !state);     // set pin to the opposite state
//callback notifying us of the need to save config
void saveConfigCallback () {
  shouldSaveConfig = true;
  ticker.attach(0.2, tick);
// The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 40);
  WiFiManagerParameter custom_D_Link_1("Link 1", "D_Link_1", D_Link_1, 40);
  WiFiManagerParameter custom_D_Link_2("Link 2", "D_Link_2", D_Link_2, 40);
  WiFiManagerParameter custom_D_Link_3("Link 3", "D_Link_3", D_Link_3, 40);
  WiFiManagerParameter custom_D_Link_4("Link 4", "D_Link_4", D_Link_4, 40);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  //add all your parameters here
  wifiManager.addParameter(&custom_D_Link_1);
  wifiManager.addParameter(&custom_D_Link_2);
  wifiManager.addParameter(&custom_D_Link_3);
  wifiManager.addParameter(&custom_D_Link_4);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  wifiManager.setMinimumSignalQuality();
  // set configportal timeout
    wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("DirectLink4")) {
      Serial.println("failed to connect and hit timeout");
      delay(3000);
      //reset and try again, or maybe put it to deep sleep
      ESP.restart();
      delay(5000);
    //if you get here you have connected to the WiFi
    Serial.println("connected...yeey :)");
    //read updated parameters
    strcpy(D_Link_1, custom_D_Link_1.getValue());
    strcpy(D_Link_2, custom_D_Link_2.getValue());
    strcpy(D_Link_3, custom_D_Link_3.getValue());
    strcpy(D_Link_4, custom_D_Link_4.getValue());
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  Serial.begin(115200);
  //sensors.begin();
  pinMode(TRIGGER_PIN, INPUT_PULLUP);
  pinMode(Link_1_PIN, INPUT_PULLUP);
  pinMode(Link_2_PIN, INPUT_PULLUP);
  pinMode(Link_3_PIN, INPUT_PULLUP);
  pinMode(Link_4_PIN, INPUT_PULLUP);
  pinMode(onboard_led, OUTPUT);
  // start ticker with 0.6
  ticker.attach(0.6, tick);
  if (WiFi.SSID()==""){
    initialConfig = true;
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        // Allocate a buffer to store contents of the file.
        DynamicJsonBuffer jsonBuffer;
        Serial.println(jsonBuffer.size());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(D_Link_1, json["D_Link_1"]);
          strcpy(D_Link_2, json["D_Link_2"]);
          strcpy(D_Link_3, json["D_Link_3"]);
          strcpy(D_Link_4, json["D_Link_4"]);
        } else {
          Serial.println("failed to load json config");
  } else {
    Serial.println("failed to mount FS");
  host = Supla_server;
  WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
void loop() {
 if ( digitalRead(Link_1_PIN) == LOW )  {
    url = D_Link_1;
    direct_Link() ;
   if ( digitalRead(Link_2_PIN) == LOW)  {
    url = D_Link_2;
    direct_Link() ;
  if ( digitalRead(Link_3_PIN) == LOW )  {
    url = D_Link_3;
    direct_Link() ;
   if ( digitalRead(Link_4_PIN) == LOW)  {
    url = D_Link_4;
    direct_Link() ;
    // is configuration portal requested?
  if ( digitalRead(TRIGGER_PIN) == LOW|| (initialConfig))  {
    ondemandwifiCallback () ;
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    json["D_Link_1"] = D_Link_1;
    json["D_Link_2"] = D_Link_2;
    json["D_Link_3"] = D_Link_3;
    json["D_Link_4"] = D_Link_4;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    //end save
    ticker.detach();
    digitalWrite(onboard_led, HIGH);
  if (WiFi.status() != WL_CONNECTED)
    WiFi_up();
void WiFi_up()
  WiFi.begin();
  for (int x = 60; x > 0; x--)
    if (WiFi.status() == WL_CONNECTED)
      break;
    else
      Serial.print(".");
      delay(500);
    ticker.detach();
    Serial.println("");
    Serial.println("Connected");
    Serial.println("Adres IP: ");
    Serial.print(WiFi.localIP());
    Serial.print(" / ");
    Serial.print(WiFi.subnetMask());
    long rssi = WiFi.RSSI();
    Serial.print("(RSSI): ");
    Serial.print(rssi);
    Serial.println(" dBm");
    Serial.print("(Port): ");
    Serial.print(httpsPort);
  else
    Serial.println("");
    Serial.println("connection failed to wifi");
void direct_Link() {
  // Use WiFiClientSecure class to create TLS connection
  WiFiClientSecure client;
  Serial.print("connecting to ");
  Serial.println(host);
  Serial.println(httpsPort);
  if (!client.connect(host, httpsPort)) {
    Serial.println("connection failed");
    return;
  Serial.print("requesting URL: ");
  Serial.println(url);
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "User-Agent: BuildFailureDetectorESP8266\r\n" +
               "Connection: close\r\n\r\n");
  Serial.println("request sent");
  while (client.connected()) {
    String line = client.readStringUntil('\n');
    if (line == "\r") {
      Serial.println("headers received");
      break;
  String line = client.readStringUntil('}');
  line = line + "}";
  Serial.println("reply was:");
  Serial.println("==========");
  Serial.println(line);
  Serial.println("closing connection");
in the serial console i have:
could this be the fault of the certificate?
my domain has a green certificate from let's encrypt, but it doesn't work after port 443 (proxy) :/
you are able to compile for port 4443, maybe I have some other library?
Posted: Mon Dec 16, 2019 11:43 pm
by elmaya
compile using:
esp board manager 2.4.2
iwip Variant V2 higher Bandwidth
i think later versions doesn't work
Posted: Mon Dec 16, 2019 11:59 pm
by szym3k
I compiled with these settings and it works. Thank you!
I used 2.5 before.
Posted: Tue Dec 17, 2019 12:04 am
by elmaya
szym3k wrote: Mon Dec 16, 2019 11:59 pm I compiled with these settings and it works. Thank you!
I used 2.5 before.
I'm sorry for the inconveniences.
That is the only one in which it is not spesified.
I will correct.
Posted: Sun Jan 05, 2020 8:09 pm
by bulek68
My construction concept for SUPLA Direct Link by elmaya. ;)
Posted: Mon Apr 20, 2020 11:54 am
by ritual
i tried using x4 and x6 direct links softwares and i was not able to send request from it.
i was successful in flashing and connecting it to my wifi but when i connect the specified pin to ground nothing happens.
is there anything specific i need to do, like in links should it be read/toggle or for devices should be turned on or something.
Posted: Mon Apr 20, 2020 12:12 pm
by elmaya
directlinks must contain the action "/ toggle, / turn-on, / turn-off" for devices must be disabled.
example:
Posted: Fri Apr 24, 2020 11:01 am
by ritual
I tried using toggle previous time but it didn't work,tho i will try once again and let you know. Thank you for your help.
Posted: Sun Jun 14, 2020 11:42 am
by arkomp
prośba o pomoc w uruchomieniu sterowania z d1mini 8 linkami.
Polutowałem zgodnie z poniższym schematem, wgrałem soft, wpisałem ustawienia do d1mini - łączy się z wifi ponieważ dioda nie mruga ale nie wysyła linków. Już nie mam pomysłu co może być problemem
Posted: Sun Jun 14, 2020 12:13 pm
by elmaya
have you uploaded the bin file with the correct setting?
