thermostat with adjustment from the app
jaros12
Sun Mar 01, 2020 3:18 pm
Hello,
does this additional D5 relay work? Anyone installing? On my Nodemcu, the thermostat works OK, and this additional one does not respond at all ... I uploaded the finished @elmaja file and it also does not work.
Regards
elmaya
Mon Mar 02, 2020 10:33 am
Hello,
Regards
Can't you see the channel in the App?
do you see it but it doesn't change?
jaros12
Mon Mar 02, 2020 11:11 am
The relay channel is visible in Supla, it just doesn't switch.
Nodemcu is OK after replacing Gpio, the thermostat works correctly also on the second output.
kris.sg
Wed Mar 25, 2020 4:58 pm
Hi Elmaya
Can you share your SuplaDevice library
I try compile but it give error:
'class SuplaDeviceClass' has no member named 'channelDoubleValueChanged'
b.r.
Kris
elmaya
Wed Mar 25, 2020 5:28 pm
Hi Elmaya
b.r.
Kris
is the usual Supla 1.6.1 library.
https://github.com/SUPLA/arduino
kris.sg
Thu Mar 26, 2020 9:44 am
thx for the help
i replace supladevice lib but there is another problem:
In file included from C:\Users\Kris\Documents\Arduino\Supla_termostat\supla_termostat.ino:11:0:
C:\Users\Kris\Documents\Arduino\libraries\ESPEFC-master\src/ESPEFC.h:4:7: error: using typedef-name 'using ESP8266WebServer = class esp8266webserver::ESP8266WebServerTemplate<WiFiServer>' after 'class'
 class ESP8266WebServer;
In file included from C:\Users\Kris\Documents\Arduino\libraries\WiFiManager/WiFiManager.h:48:0,
                 from C:\Users\Kris\Documents\Arduino\Supla_termostat\supla_termostat.ino:7:
C:\Users\Kris\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:229:80: note: 'using ESP8266WebServer = class esp8266webserver::ESP8266WebServerTemplate<WiFiServer>' has a previous declaration here
 using ESP8266WebServer = esp8266webserver::ESP8266WebServerTemplate<WiFiServer>;
exit status 1
Błąd kompilacji dla płytki Generic ESP8266 Module.
elmaya
Thu Mar 26, 2020 11:04 am
thx for the help
exit status 1
If you read attentively the first line of the code you will see ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth.
you have 2.6.2 (change it).
attached ESPEFC library
ESPEFC-master.rar
(3.35 KiB) Downloaded 3 times
kris.sg
Thu Mar 26, 2020 1:01 pm
now everything is ok
thx Elmaya
my mystake, I thought there might be a higher version board manager :)
Post Reply
